- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi home wifi dual band / RBK13 will not connect to my internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm very frustraded right now. I bought the Orbi Whole home wifi system / Dual Band / Model RBK13-100 and have follow all of the prompts with no success. I get to the end of the set up for it to tell me it can not detect my internet, therefore it will not link up. This system is over kill for my 1938 sq ft house, but i need it for my business. Im using a nighthawk AC1750 router / modem and im wondering if thats the problem. If anyone has suggestion on what to do to correct this problem it would be greatly appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi home wifi dual band / RBK13 will not connect to my internet.
If the modem has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I know the NG modem can be bridged so try option #1 first....
