rhg76's avatar
rhg76
Tutor
Feb 21, 2021
Orbi iMac issues
Hi there
I wonder if someone can help. FURRYe38 was incredibly helpful before when I had backhaul issues - all sorted now.
My iMac is losing wifi connection intermittently. All other devices are OK.
I've attached some screengrabs from Orbilogin.net.
  • The two satellites look good
  • However, the iMac (highlighted in the red box) says it's connected to the 'Orbi Satellite', not a specific named satellite ('Breakfast Room' or 'Upstairs') ... this seems weird
  • Also, when selecting the device (I checked this is the correct device by finding the IP address in wireless settings), it shows as a Macbook Pro 13"  and a Laptop when it is in fact an iMac.
Could the above be part of the problem?
Any advice would be great!
Thanks
Rob
  • Here's the other screenshot
  • I have long since noticed the RBR dropping the WiFi signal both 2.4GHz & 5GHz. Attached are several screen shots of real time analysis of the signal. Some devices are more sensitive to that behavior than others.
  • FURRYe38's avatar
    I have noticed that my Mac Book Pro seems to loose connections when I'm sitting in my living room thats around the wifi overlap area between the RBR and RBS. I notice this more if I have two RBS online then just one. Odd that this only happens on Orbi AX. Doesn't happen on Orbi AC for me.
    • FURRYe38's avatar
      Forgot to mention that it's less prominent since I reduced the RBR output from 100% to 50%.
