Reply
Highlighted
Orbi iOS app not seeing Satellite
Hi,
Have just installed Orbi and all working great. Loving it so far.
Although I can see that the satellite is connected and online and apparently working fine, the iOS app reports 0 satellites. And it fails to find If I search.
Is this a known issue ? When I search on the app do I have to press pair *again* on both router and satellite in ortder for the app to see the satellite ? (Even though the pairing *has* worked) and I can see the satellite from the router home page.
TIA
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
Highlighted
NETGEAR Moderator
Re: Orbi iOS app not seeing Satellite
Hello cpmolloy
If you can log into the router page and go to attached devices and see the satellite attached I would say that is a bug with the app.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1837 views
  • 0 kudos
  • 2 in conversation
Announcements
