- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi iOS app
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi iOS app
I purchased and installed the Orbi RBR50 this week in the hope it would improve Wi-Fi coverage in my home. I believe it is doing that function, but intermittently. More of that later.
My initial issue is with the iOS app. From the home screen the app states RBR50 with “Connected Locally” underneath and a green dot beside it. I tap on it and am taken to a second screen which states RBR50 with “Connect Locally” stated underneath. This is preceded by a dialogue stating “You are not connected to the internet. Check your internet connection and try again”. This is baffling as I am clearly connected to the internet.
Any advice greatly appreciated. By the way I am in no way an IT expert.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi iOS app
I have found out what the problem is. It relates to VPN.
If I disable VPN the connected screen states “Connected Locally”. Although I still receive the dialogue stating I am not connected to the internet.
Furthermore I have to disable VPN if I want to engage Remote Management.
is this issue with VPN a known bug?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi iOS app
Is the Orbi system operating in Router or AP mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi iOS app
Many thanks for responding. To answer your questions:
The current firmware is 2.3.1.48
The router is a BT Home Hub 6
The Orbi system is operating in router mode. However from what I have read in the forum I believe I should switch it to AP mode.
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi iOS app
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi iOS app
You do need to use the Orbi in AP mode if you are using the BT HH6. It is not possible to put the HH6 in modem only mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi iOS app
Can use DMZ if that available on the ISP modem...Then one can use the Orbi in router mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi iOS app
Thanks for your responses.
I have put Orbi in AP mode and so far things seem to be stable.
Two things I have noticed is that Netgear is showing the backhaul status on the satellite as Poor and I have to disable VPN for the app to function.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi iOS app
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
I don't think the Orbi app works across VPN.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi iOS app
If you want to use the iOS app while using a vpn, you have to first enable remote management on the orbi (while using the web app) and then access “remotely” from the iOS app. = just as you would if you were actually across town or across the world instead of just virtually on a different network through the vpn
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi iOS app
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi iOS app
The size of the house is circa 1800sq ft.
The router is situated on the first floor and the satellite on the ground floor. I would say it is about 40 feet between the two. The house is timber frame with no brick walls within the building. What I should also add is that the backhaul status is now showing Good. I don’t know what has changed but I am now happy with the setup which has been running trouble free (touch wood!) for 24 hours. Although I have yet to attach the second satellite.
May I thank all the respondents for taking the time to help me out. It is greatly appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi iOS app
Ok, just checking placement of system. Distance is key between the RBR and RBS.
IF it seems to be working well, then save off a configuration backup to file for safe keeping.
Enjoy.
