Reply
Highlighted
Orbi jittery with ring central
Ring central voice calls are impossible on my orbi router. 1gb connection, and the calls either jitter or drop.
Message 1 of 6
Highlighted
Guru
Re: Orbi jittery with ring central
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
My Setup (Cable 900Mbps/50Mbps)>CAX80>XR450 v2.3.2.106(Router Mode)>RBK853 v3.2.11.2(AP Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 6
Highlighted
2.3.1.48
Router Mode
3400
1 Satellite ,~50 ft
I'll try that
A dozen or so strong signals
WPA2-PSK [AES]
All enabled
I'll try
THANK YOU
Message 3 of 6
Highlighted
Guru
Message 4 of 6
Highlighted
Arris CM3200
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 5 of 6
Highlighted
Guru
Also give disabling SIP ALG a try as well:
https://community.netgear.com/t5/Orbi/Wifi-calling-and-Orbi-on-iPhone/m-p/1742342/highlight/false#M6...
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 650 views
  • 0 kudos
  • 2 in conversation
Announcements
