- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi keeps desconecting
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi keeps desconecting
Netgear suport team didn’t reply to my case
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
@Salmutairi wrote:
I just set up orbi 53 and updated it but i notice it keeps disconnecting every 30 minutes it is not isp provider issue it is the mesh system issue. The router connected to netgear m1. M1 wifi disabled. The router and its 2 setlites are green they are close to each other.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That is probably the MR1100 Mobile Router. Disabling wifi does not disable the router. But disabling the router does disable the wifi.
There is support for the MR1100, including a manual, somewhere at the end of this link:
>>> MR1100 | Product | Support | NETGEAR <<<
Check the section Enable IP Pass-Through Mode or consider putting the Orbi into wireless access point (AP) mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
