- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi keeps dropping internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
This started happening AGAIN with firmware version 2.1.1.16. drops internet and I have to keep resetting (gets a purple ring on the router). I re-installed 2.1.1.12 to try to fix it after reading others were having trouble and this version was removed from the auto updates. It’s still dropping the connection. ANy help is much appreciated. Resetting this is getting OLD! This happened all of Thanksgiving weekend too!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi keeps dropping internet
Have you checked your modem when your orbi is showing no internet to see if it has been losing connection as well?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, we never lose internet connection from the cable modem. Resetting the orbi and satellite fixes it, but only for an hour.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having the same issue... very frustrating. This needs to be fixed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same thing. Droping interenet all the time now. 2.`1.1.16 firmware. This is freaking rediculous.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You may want to try the 2.1.2 beta that has fixes for issues from the 2.1.1 firmware.
https://community.netgear.com/t5/Orbi/OrbiOS-2-1-1/m-p/1476960#M19962
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been haviing the same probem. Im losing connection multiple times per day and have had this on and off since I started using the Orbi. I'm on 2.1.1.16 and I've done the factory reset and reconfigured afterwards. Still the same. As others have said, we don't expect a premium product like this to have so many problems. I "upgraded" to this from a Nighthawk X4S (R7800) because I needed the wired connection from the Satellite. Otherwise, the X4S was a much better router - it had the same coverage as the Orbi system gives me, higher speeds, and no disconnects.
Has the 2.1.2 beta fixed the problem for anyone?
