- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Orbi keeps rebooting several times a day even with new firmware V2.5.1.16
House: 3200 sq.
Comcast: Internet
Router and satellite are around 30ft., no walls blocking them
Modem Arris SB8200
Firmware updated automatically through admin page (V2.5.1.16)
I'm having the same issue as many others it seems and have been for months. I didn’t know it was so bad and frequent till this quarantine. Out of all the discussions on this I've only seen 1 resolved and that was a product defect. All of the other suggestions didn’t help anyone it seemed as they were addressing internet issues or interference.
I wish I would have caught this during the 1st 3 months , now they want to charge me 90 dollars to do what I assume would be what everyone has described. It’s not my internet it’s this Orbi product, I never had these issues before this.
I would love for this to work as everything but this issue has been great. The coverage and ease of setup was top notch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Orbi keeps rebooting several times a day even with new firmware V2.5.1.16
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I've tried some, but every post I read with the same questions none of what was asked changed anything. As with the others some of these are already disabled as a default i.e. Daisey Chain and a few other. I have not done a factory reset and I will change the channels though it’s not an internet issue it’s a Orbi issue.
I do appreciate the help and will have to change the rest later after work but really it doesn’t seem like others Wi-Fi is making it reset. I have neighbors all around me but I’ve always had them and never had this rebooting issue till I got Orbi. I really like the ease of use but this is such a hassle and a pain since we work from homes these days.
I might have to consider the factory reset option but need to read up on what all I have to do in order to do it correctly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Please give feedback to the question presented when you get a chance.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Is the Orbi system operating in Router or AP mode?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
@pshah wrote:
I have been having the exact same issue with this firmware version. Orbi reboots 6-7 times a day. I have done factory reset and still nothing. Very frustrating.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Any progress on this?
@guilloryjc wrote:I've tried some, but every post I read with the same questions none of what was asked changed anything. As with the others some of these are already disabled as a default i.e. Daisey Chain and a few other. I have not done a factory reset and I will change the channels though it’s not an internet issue it’s a Orbi issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
If your unit is rebooting itself spontaneously, forget all the contortions and resetting and questioning your modem and house size. It's defective. It's what happened to me. There is a flaky component, one possibility is bad RAM, where memory data gets corrupted.
Once I got a replacement router, it's been solid...so far.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Lets see if this is a configuration or other wise first before claiming it's a HW issue. Trouble shooting needs to be done first. Not every unit is faulty.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks for the suggestions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Glad the suggestions helped.
Please mark your thread and solved so others will know.
Enjoy.
@pshah wrote:
I have had the router for 3 years so definitely not a faulty hardware. I try tweaking the settings one at a time and so far changing 2.4ghz channel to 1 after factory reset helped. Over 24 hours with no reboot. Channels 6 & 11 did not help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Oopps I didn't scroll down far enough. Sorry about that. Hopefully the OP can gain same resolution as well. We'll wait for there responce.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I will have to try the factory reset this weekend then try changing he channels. I've had these issues since purchase.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You might try the new FW update on your ssystem. Manually download the FW files and install them. RBS first then RBR lastly. I would factory reset the system after the update then setup from scratch and see how it goes.
If this still fails, then I would contact NG support and open a support ticket.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I tried everything and finally downgraded router and satellite to 2.5.1.8. Its been stable for a while now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ok, next time an update is seen, update the RBS first, then the RBR lastly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Usually when any router reboots itself several times a day, it can be getting overheated or defective, or a bad or going bad power supply. I had an Orbi power supply cause an RBR50 router go on and off every 10 seconds, just like a timer was controlling the power. If possible try a different equivalent power supply and see if the problem goes away.
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
There's always a logical answer, if you have all the facts!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Still having the exact issue , I've done everything mentioned. I've restarted from default, I've started with satellite first, I've changed all the settings and still as of today I'm still having the issue. It has restarted 3 times already, this is so ridiculous. Unless someone has any new suggestions I will now have to pay another 100 for them to do all the same things and figure out I have faulty equipment. I can promise you one thing, I will never buy another Netgear product. This issue is 100% Netgear and not my internet or settings. I only wish I would have noticed this when it was still under warranty.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@guilloryjc wrote:Still having the exact issue , I've done everything mentioned. I've restarted from default, I've started with satellite first, I've changed all the settings and still as of today I'm still having the issue. It has restarted 3 times already, this is so ridiculous. Unless someone has any new suggestions I will now have to pay another 100 for them to do all the same things and figure out I have faulty equipment. I can promise you one thing, I will never buy another Netgear product. This issue is 100% Netgear and not my internet or settings. I only wish I would have noticed this when it was still under warranty.
Do NOT pay Netgear $100! You have defective hardware. No setting or configuration should ever cause a spontaneous reboot.
I had the same issue but luckily it was well within the warranty period and they sent me a "new" replacement unit which was actually a USED router - shipped in a generic padded box, the case was worn, and I checked the serial # and it was quite old. But it addressed the problem and I never get a spontaneous reboot, ever.
My recommendation is to buy another brand. But don't give Netgear any more of your money; they will just take your $100 and say you need a new router, so sorry, it's out of warranty.
