- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi log : [Initialized, firmware version: V2.0.0.74]
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm continuing to work out what's happening with my Orbi.. Have been having various disconnection issues, which I thought was ISP related, but which seem to have stabilised since applying 2.0.0.74 firmware. However, I'm also seeing fairly regular appearances in the logs saying;
[Internet connected] IP address: 192.168.n.nn (which is the IP address assigned by the cable modem)
This is all at the start of the log at that point, which I think suggests Orbi has restarted - not sure..any thoughts out there?
Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi log : [Initialized, firmware version: V2.0.0.74]
Got the same here. I upgraded after the problematic 1.2.00.18 release but this version also causes my Orbi system to reboot spontaneously at times. Sometimes it works fine for 1 to 2 hours, while at other times it reboots every couple of minutes. I just did a factory reset (again) and reconfigured things again from scratch. I'm only using my Orbi as an access point (not as a router).
- Mark as New
- Bookmark
- Subscribe
- Permalink
@DCP4971 wrote:.. I'm also seeing fairly regular appearances in the logs saying;
I guess you are using the Orbi as an AP?
I am wondering if you have tried Netgear support on this issue. To me if there was nothing that was initiating that reboot like a power fluctuation I would start to think this is a hardware issue.
