- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Orbi loosing Internet Connection on iPhone
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi loosing Internet Connection on iPhone
Hi all!
Tried all the suggestions and the problems remains the same.
Did a new setup from scratch with all default settings and I have realized that the issue occurs only when the satellite is wired to the router. If the satellite connects to the router wirelessly the connection to all my iOs devices works perfectly. But I can't keep it as is because:
- Connection between the satellite and the router is fair or poor, even if I try moving the satellite to other places on my 1st floor (lights either solid amber, magenta at times). The size of the house is not an issue, it's more the material used in the wall I guess.
- Internet speed is below 6Mbps on my iMac if satellite is in the same room and dosen't receive any WiFi signal if the satellite is placed in another room.
I obviously tried to change all the cables (other than the one which goes in a wall between ground and 1st floor) with no improvment..
Any help greatly appreciated.
Thanks!
aty
@aty1972 wrote:
Hi!
All iOs devices are updated and I've just added them to the address reservation.
The rest was already enabled.
Will give this a go and see what happens.
Thanks!
@JammasterC wrote:
Make sure your Apple devices are updated.
Have you used "Address Reservation" on the LAN setup page at orbilogin?
Enable Fast Roaming, Beamforming, and MU-Mimo.
Give these settings a chance as I believe that changing settings on the router is not immediate and needs time to register.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there a LAN switch or patch panel between the router and this satellite or directly connected?
Is Daisy Chain enabled or disabled? Recommend disabling Daisy Chain if you have a satellite that's wired to the router.
Is Beamforming enabled?
You can try the new FW:
You have to update the satellite first, then when you update the RBR, load v212 first, then v32.
@aty1972 wrote:
Hi all!
Thanks!
aty
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please try to upgrade to this software.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi!
I should have mentionned that I've already upgraded to the new firmware and that both the RBR and RBS are running 2.3.0.32 with no improvement.
The satellite is directly connected to the router.
Daisychain disabled
Beamforming enabled
20/40 MHz Coexistence disabled
Preamble Mode Long
CTS/RTS Threshold 2341 Sat 2345 Router (tried 2307 on both as well)
Mu-Mimo and fast roaming whether enabled or not has no impact on connection
As am I writing this it took 2 minutes for my iPhone to connect to the internet (WiFi strength full) and for example the orbi app didn't even detect my router and satellite the first 2 times it was trying to detect my product.
@ekhalil wrote:
Few Issues related to Ethernet Backhaul were fixed in the latest software 2.3.0.32. As you see this issue only when using wired backhaul, it’s very likely that you get good improvement with the new software.
What I don't understand is how come my iMac has a very stable connection (ran a ping test on google with no issue) while being connected to the 5Ghz network of the satellite and at the same time my iPhone keeps on dropping internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What other device types do you have attached to the network? What devices do you have wired to Orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
To the router:
2 iPads 2.4G
1 iPad 5G
1 surface tablet 2.4G
1 sonos soundbar 2.4G
1 iptv 2.4G
To the satellite:
My iPhone and iMac both to the 5G channel
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@aty1972 wrote:
At the moment:
To the router:
2 iPads 2.4G
1 iPad 5G
1 iptv 2.4G
To the satellite:
What type of IPTV device do you have? Can you please test to disconnect the IPTV and see if there will be any difference? Can it be that IPTV multicast data is impacting the Orbi performance?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will give it a go to see if this impacts on the stability of the network.
Weird as well that everything works well if the sat is not wired to the router (although not usablein this config since wifi and speed is very bad)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you happen to have enabled VLAN / Bridge Group to make the IPTV work?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've disconnected the IPTV and will advise if there's any improvement.
VLAN / Bridge Group has always been disabled
- « Previous
- 1
- 2
- Next »
