- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Orbi loosing Internet Connection
ON .34 Firmware. Devices starting dropping an hour ago Rebooted. It is back up. Let's see for how long!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Saturday, January 07, 2017 15:31:19
[Internet connected] IP address: 77.xx.xx.xx, Saturday, January 07, 2017 15:26:47
This never happend with my previous router but seems to be normal with this one. Started directly after my router switch. Totally unacceptable (not that fun watch Netflix or HBO with this internet flickering going on).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I was banging my head againts the wall trying to figure out why my Orbi kept dropping my WiFi signal to the point where I was ready to return it to BestBuy. I was changing all sorts of settings in the administrator console and finally found the solution that worked for me. It was much easier then then I thought.
I found that I had my Satalite unit much too close to my Primary unit which meant that it kept fighting for ownership of which unit will provide the WiFi to my device. When that happens, it ultimatly disconnects from one unit and connects to the other unit and it appears that my WiFi has dropped again. After I moved my Satalite unit further away from my Primary unit, it solved this problem for me. No more WiFi dropping issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
.16 I have found to be the most stable at the moment you can roll back to it then do factory reset until Netgear release a stable Firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I rolled back to .16 today. Hopefully that will keep it up. I don't remember any disconnects with that version of firmware. Let's hope the Orbi doesn't do an auto firmware update!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I've been having the same dropped connection issues while using the 1.4.0.34 firmware.
Symptoms:
- Internet drops on wireless only for a few minutes at a time (2-3 times a day).
- Wired connections continue to work just fine indicating the issue is only with Orbi.
I just rolled back to the 1.4.0.16 firmware. Will report back in a few days with results.
Thanks for posting about this, it really helped me track the issue down.
Is the factory reset necessary after installing new firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Bad new. I rolled back to .16 yesterday and this morning, the router lost connectivity. Had to power cycle. If this continues another couple days this is getting returned!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I'm running into the same issues again - seemed to be pretty stable but latest has been bombing out quite a bit. I did see it with .16 a little as well. Essentially what happens is that even though devices are connected (such as a computer or iPad) - and have a DHCP address - it will not be able to get to the Internet. Usually you can just turn off the wireless and turn it back on - and it'll come back up. I've also noticed that computers will sometime lose their DHCP address and have to do the same thing in order to get it again. Last night though, even turning it on/off - it still wouldn't connect. Had to power cycle the router and after that - everything seemed to come back up.
Seems very sporadic - mostly Apple devices causing it - but very unstable at this point.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Factory reset not required but I personally recommend it to mitigate any issues and for consistency, this way everytime I upgraded or downgrade I always have done a factor reset to be consistent in my testing results and one less unknown factor to rule out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Today I decided to connect my Apple TV via lan cable to a switch then to the Orbi Router not Sat.
Interestingly enough I noticed 2 drops on internet on the Apple TV even on Lan cable within about 60 mins and a immediate reconnect.
I therefore setup the exact same network switch cables etc. and this time connected it to my R8500 instead of using Orbi.
No Drops of internet connection in 60 mins.
So I am beginning to think there are two issues here. 1. The wifi drops. 2. The internet drops (Both on Lan and wifi)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
And just info on the Wifi drops.
Noticed drop on Macbook Pro this morning 100cm away from the main Orbi Router. At the same time my iphone also dropped the Wifi connection to the Orbi Router.
So it's not a single device issue its dropping multiple devices at the same time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I've suffered from WiFi and Internet drops on both .18 and .34. I'm using the Orbi in AP mode with a Asus AC-RT66U acting as router/DHCP server with WiFi turned off.
Checking the logs on the Orbi I could see that it was reconnecting to the Internet every 12 hours , and that's when the disconnects were happening. The DHCP lease on the Asus is 12 hours.
The problem could be with the Orbi or the Asus but changing the Orbi to a static IP address has solved the issue. No disconnects in 3 days.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Buckaude wrote:
Same issue as most folks. I tried changing my mtu 1492. I am on fios and lose connection at least once a day, generally at the same time which is around 3pm. I'll see how it goes with the mtu change.
If you're determining that the disconnects are happening based on the log entries, I'm not so sure - in AP mode, my Orbi reports internet 'disconnections' each time it reaches out to renew its DHCP lease. If it's every 24 hours, it's llikely a false alert.
Now if you're *really* losing connectivity (and you can observe it happening), that's different...but surprising.
You shouldn't need to adjust the MTU on FiOS at all, it's not packet-switched.
Rodney
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Just an update, still no disconnects after a week (or at least none that anyone in the house has noticed), since changing the Orbi router's IP to static - I'm using the Orbit in AP mode.
Rodney - I appreciate that using log entries to determine disconnects is not the best method. But I was looking at the logs after connectivity was lost (and by lost I mean on all devices). I could see the reconnect log entry (which I'm certain happens because of the DHCP renewing its lease, as you say), and the times on multiple occasions tied in with losing connection. That's as much as I can say.
I also appreciate many people are having disconnects when not in AP mode, but a static IP is worth try if you are in AP mode.
Let's hope Netgear provide another firmware update soon.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have been able to mitigate this to an extent by rolling back to 1.4.0.16 with a factory reset same issue started in 1.4.0.18 and persist in 1.4.0.34 eagerly waiting on next Firmware release with fix.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@JMU1998 wrote:I have been able to mitigate this to an extent by rolling back to 1.4.0.16 with a factory reset same issue started in 1.4.0.18 and persist in 1.4.0.34 eagerly waiting on next Firmware release with fix.
plz stop spamming the same comments over various threads as many dont have your issue , many have no issue at all with the latest fw
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Just to add weight to this conversation - I am having the same problem. My drops are in the 5-10 seconds range and happen up to 10 times a day. This is OK most of the time but I work from home and conference calls, webcasts, etc. are totally useless. I have two networks at home so will solate the problem by joining my other network and monitoring.
Wouldn't it be cool if one of the network equipment providers would provide a decent network monitoring software showing ping speeds, internet availability, up- and down-load speeds, etc so we wouldn't have to use a variety of tools to troubleshoot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Any as you were told in other threads, MANY DO have issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Not trying to spam just "emphasising" the facts and trying to help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
New Orbi user here. Like all of you, I've been having many issues with the orbi dropping internet connections. Having seen this problem on previous routers, when IPV6 is on, I disabled IPV6 and the network seems to be back up and running well.
Hopefully this helps all of you with your issues as it seems to solve dropped internet connections for me. I'll check in again in a few hours to confirm if it holds strong for the day!
Love the device but still figuring out how to make it work well like my previous nighthawk router!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
NETGEAR is aware of an issue affecting some users where wireless client devices frequently disconnect/reconnect from the Orbi WiFi network. We’re actively working on the issue and hope to have a solution soon.
Thank You
DarrenM
