Orbi WiFi 7 RBE973
Reply
Orbi loosing internet connection
Mike34848
Hi all,
problems with my orbi loosing internet connection. I have had this orbi for several months and it had been working super.
Now it is connected to my modem for max 30 seconds and then it loses connection every single time.
I have resetted to factory default settings and updated the firmware to 1.12.018, the very last version.
Any ideas please, or should I return the unit
regards Mike
Message 1 of 7
DarrenM
Sr. NETGEAR Moderator
Re: Orbi loosing internet connection
Hello Mike34848
Have you tried to enable beamforming and mumimo some people have said since the update when they enable it again seems to fix the issue.
DarrenM
Message 2 of 7
thedigitaltuner
Same issue for me since the purchase of router and two satelittes.  Completely losing the internet on latest firmware verison.  Really frustrating as when traveling I lose acessess to my cameras and the thermostats.  Can't believe how expensive for how bad.  When i get home I am going to have to go back to my old router.  The orbi even after updates has the same problem of losing connection even when no one is home using it, falls over and does not recover.  Really big issue and no solution.
Message 3 of 7
DarrenM
Hello thedigitaltuner
Have you done a factory reset since being on the latest firmware?
DarrenM
Message 4 of 7
Mike34848
Hi DarrenM,
thanks for your ideas. I have been away a few days, but I will try enabling beamforming and mumimo. I first have to find out how to do that...
And I will try the factory default reset first, have not done that after the firmware update.
mike
Message 5 of 7
thedigitaltuner
I have not done a factory reset, that sounds painful as assume i would lose all settings.  Why would that be required?  Is this not your top of the line equipment?
Message 6 of 7
DarrenM
Hello thedgitaltuner
You can backup your settings before the factory reset. All you need to do to factory reset the unit is hold the reset button for 10 seconds. I linked how to back up your config.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
DarrenM
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2921 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
