Orbi WiFi 7 RBE973
Reply
Orbi losing speed between units
Monica123
Follower
Have 50 Mb download speed at modem.  Constantly fluctuating signal at both add on Orbi units, but never achieving more than 15 Mb downloads.  Have 3 units in 4500 sq ft house.  constantly having buffering coming on during all times of day trying to watch streaming shows.  fluctuating and sometimes on /off internet access in various parts of house....... suggestions???
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 2
Guru
Re: Orbi losing speed between units
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1072 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
