Reply
Orbi mini router has been assigned an apipa address
Slagman
Follower
I just set up my Orbi mini router and now the IP address is an apipa. My service comes in to my home and connects to my Comcast modem. I then connected my Orbi to the internet port as directed. Is it supposed to be apipa?
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 4
Guru
Re: Orbi mini router has been assigned an apipa address
What FW is currently loaded?
Is this address seen on the routers web page or the PC? APIPA comes from adapters or devices that can't get IP addressing from a DHCP server correctly or a LAN cable is bad or not connected fully.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.1/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 4
Blanca_O
NETGEAR Moderator
Hi @Slagman
Welcome to NETGEAR Community!
Does it affect all devices connected to the network? Were you able to complete the setup wizard when you set it up? Please try to turn off and on the affected device and check again the IP address.
Blanca
Community Team
Message 3 of 4
Blanca_O
NETGEAR Moderator
Hi @Slagman
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 435 views
  • 0 kudos
  • 3 in conversation
Announcements
