Reply
Orbi new system gets random disconnections and random decrease
Phis213
Initiate
I just bought the Orbi WiFi home system, I am upgrading from a Netgear R6300. I have four days with my Orbi and I am having issues with random disconnection and random speed decrease. I followed videos from Netgear on how to set it up and the guide that came with it. I even updated the firmware as soon as I was setting it up. I love the Orbi when it properly works,  the speed amazing  and the coverage it gives is really good. However, as I mentioned before, I am experiencing disconnection from the internet and the speed decreases here and there.  Is anyone experiencing any random disconnections or random decrease? I live in a 1414 SQFT house.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 7
DarrenM
Sr. NETGEAR Moderator
Re: Orbi new system gets random disconnections and random decrease
Hello Phis213
Have you disabled MUMIMO and beamforming?
DarrenM
Message 2 of 7
SSuffolk
Guide
Having the same problems, devices randomly disconnect.
Message 3 of 7
SSuffolk
Guide
Mine are disabled, would it help to enable them?
Message 4 of 7
DarrenM
Hello SSuffolk
If they are both disabled you can also try another fix by going to Advanced-Advanced setup- wireless settings and turn down the power level of the 2.4ghz network this has worked for some people. We are working on a fix for these issues in a future firmware.
DarrenM
Message 5 of 7
Acdc2704
Tutor
How do you turn down the power level?
Message 6 of 7
DarrenM
Log into your orbi at orbilogin.com then go to Advanced-Advanced Setup-Wireless settings and you will see a drop down that says 100% lower that setting.
DarrenM
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2260 views
  • 7 kudos
  • 4 in conversation
Announcements
