- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi not connecting to the correct orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Router and that one connects to the one on the first floor, than that one connects to the one in the living room, and the one on the second floor.
But I want it to go like:
Router connect to Living room and first floor, and first floor connect to second floor.
How can I change this?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi not connecting to the correct orbi
I am not aware of any method to force how satellites connect except with a wired ethernet cable. And, if there were some "trick", such as changing the order they are turned on, it would all go away with the first power outage. Orbi has code that looks at the signal strength of the various radios and decides how to connect. What seems "wrong" to we humans may be "good enough" as far as Orbi is concerned.
Is the performance adequate?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Only thing you can do is enable Daisy Chain if you want to have RBS piggy back of each other in a line.
https://kb.netgear.com/000048458/What-is-daisy-chain-and-how-does-it-work-with-my-Orbi-WiFi-System
https://kb.netgear.com/000048460/How-do-I-disable-daisy-chain-topology-on-my-Orbi-WiFi-System
https://kb.netgear.com/000048459/How-can-I-see-if-my-Orbi-WiFi-System-is-using-daisy-chain
@Harmmie wrote:
Well I have a orbi setup. But when I look at the network map on the app, the orbis are not connected to the right ones. So for example:
- Mark as New
- Bookmark
- Subscribe
- Permalink
