Reply
Follower
Orbi not getting power (Green LED won't even come on)
I have had my Orbi RBR50 for a few days now. Two nights ago, something happened and now my Orbi is not getting power. I unplugged the router and plugged it into an outlet that I had a lamp plugged into (So I know the power to the outlet was good) to no avail. The green LED on the back won't even come on. Is there anything I could do? Or would a return be my best bet? I love the Orbi, being in a metal building it's the only thing I have been able to get working and have fast enough speeds around the house to do anything.
Can anyone help me with this???
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 2
Guru
Re: Orbi not getting power (Green LED won't even come on)
Return it for another. Probably a bad power supply or the router itself if bad.
My Setup (Cable 1Gbps/50Mbps)>CM1200(LAG Disabled)>RBK853 v3.2.17.12
RBK50 v2.7.2.102
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 527 views
  • 0 kudos
  • 2 in conversation
Announcements
