- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi not recognizing Satellite Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Why does my Orbi app say it does not recognize the Orbi satellite but the devices plugged into the satellite router are showing online and active?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi not recognizing Satellite Router
as in its not showing in the attached device list ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry, yes. When I login to my account. It shows connected but no satellites found. I've logged in from my Galaxy phone, iPad, and directly on the Orbi website. All 3 show the same.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also, I'm noticing that the light on the Orbi Satellite just pulses White and then after awhile turns off. It never goes to a different color. I've tried connecting it right next to the router, 20 feet away with no obstruction and 34 feet away in another room with a wall an dcloset door obstruction.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Jtramm
If you haven't already try to factory reset the satellite and then re sync it in the same room as the router.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
SOLVED Orbi not recognizing Satellite Router
I changed the name of my satellite (default was RBS50) to something else and the iOS app would show 0 satellites attached. When I changed the satellite name back to RBS50, presto - app started recognizing it again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the firmware V2.0.0.74 and the satellite is placed only 6 feet in sight. It does not show in the app and also does not connect. It worked befor the firmware upgrade RBR 50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are both units on the same firmware version?
DarrenM
