- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi not showing devices in AP mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi RBR50 firmware V2.5.1.8 not showing any devices in AP mode.
I can see all the devices on the internet provider's router. It should have 2 satellites, many WiFI devices and network/ethernet connected devices. I've logged into the Orbi local web app admin and it shows 0 satellites and 0 devices. The mobile app shows only 2 satellites but 0 attached devices. Yes, i've rebooted the Orbi after setting up in AP mode.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi not showing devices in AP mode
Please try a factory reset and setup from scratch with the RBR and RBS.
How is the RBR and RBS connected?
Are the RBS ethernet connected or wireless?
@biocoder wrote:Orbi RBR50 firmware V2.5.1.8 not showing any devices in AP mode.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
factory reset is for lost password
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is Daisy Chain enabled? Disable it if it is.
You can try downgrading FW to v30 or give Voxels FW a try:
@biocoder wrote:
I forgot to mention that I did perform a factory reset because of this issue in an attempt to resolve it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I really don't know what action to take regarding firmware.
I did disable daisy chain. That allowed me to see devices connected to the router, RBR50, both hard wired and wifi. The mobile app shows all the devices too, but only specifically shows me that hardwired devices are connected to router. As for satellites, the web admin shows them as disconnected, but connected in the mobile app. Neither web nor mobile app shows the satellites have any devices connected to them even though I know they do based on the total number of devices actively connected on the network.
So disabling daisy chain got me closer to seeing activity, but there is still something definitely wrong.
What specific FW version is v30, 2.3.5.30? What is the reason for considering moving to that version versus any other version?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Was the FW updated on the RBSs, they should be the same version of FW as on the RBR.
I would factory reset the RBR and RBSs.
https://www.youtube.com/watch?v=cMw4ePACgc4
https://www.howtogeek.com/434350/how-to-factory-reset-a-router/
Leave off the RBSs. Setup the RBR from scratch and complete the configuration. After the RBR is setup. Take 1 RBS into the same room as the RBR. Turn ON the RBS, once the top ring LED is slowly pulsating WHITE, press the sync button on the RBR then on the RBS. Wait or the RBS to sync. Top ring should turn BLUE. Check the status on the RBRs web page. It should appear, if it does. Set a IP address reservation for it, then Turn OFF the RBS and get the 2nd RBS and do the same thing. Wait for it to sync. Check the status. It should appear. Set a IP address reservation for it as well. If both appeared in the RBR, turn off the RBS and place back in remote locations.
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Let us know if you can get this far
@biocoder wrote:I really don't know what action to take regarding firmware.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks.
Go to the download area and see if 2.3.5.30 is there
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, the firmware on the RBR and RBS is the same.
I will try to do a full reset again using the procedures you described later this weekend.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
