Orbi WiFi 7 RBE973
Reply
Orbi not visible for Nefit Easy
FlorianM
Hi all,
I just got a smart thermostat installed, the Nefit Easy. If connected to the wifi, it allows you to set your room temperature through your smartphone. However, the thermostat is unable to find the Orbi network. Laptops and smartphones have no problems finding the network.
Wifi security is WPA2-PSK and firmware v2.3.5.30.
Does anyone know how to get the network visible?
Cheers,
Florian
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 6
Accepted Solutions
Guru
Re: Orbi not visible for Nefit Easy
I would check with the Mfr of this device for wifi support information and any information regarding MESH wifi. IoT Mfrs are not known well for there support of MESH wifi and single SSID name configurations seen with Orbi.
Try this, Disable WPA security on the Orbi temporarily. Go in to the following section and uncheck "Enable 5Ghz SSID broadcast" check box. Under Advanced Tab/Advanced Settings/Wireless Settings. Save settings and reboot the RBR.
Try and see if your device will see the SSID name you set on the Orbi wifi.
How do you have the SSID name on the Orbi configured? Any special characters or spaces?
If the device seems to connect, try enabled WPA and AES again on the Orbi and then try the device with WPA enabled.
Let us know what happens...
Message 2 of 6
All Replies
Guru
Message 2 of 6
Retired_Member
Not applicable
@FlorianM wrote:
Hi all,
Cheers,
Florian
Is the initial setup performed through your cell phone?  If so, does the cell phone have to be logged on a certain frequency (2.4 or 5G)?
Message 3 of 6
FlorianM
Followed your steps but no wifi shown yet, don't use special characters for the SSID. Initial setup is on the thermostat.
Decided to reactivated the wifi on the router of my internet provider and logged on to that network with the thermostat, the remote connect app seems to work now.
Message 4 of 6
Retired_Member
Not applicable
Doesn't sound like this is solved....??
Message 5 of 6
Guru
Sounds like your device may not be compatible with Orbi WiFi. Something to ask the mfr about.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1113 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
