Discussion stats
  • 8 replies
  • 7074 views
  • 3 kudos
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
Guide
Orbi not working after 5 months
Woke up to no wifi today. Of course beyond the 90 days of support. Satellite seems to connect to unit (get blue light) but can not connect any phones, ipads, computers. Asks for orbi password but then just waits and pops up asking for password again. Unplugged/waited/plugged back in with no changes. Hit little reset button with no changes. Not the most tech savvy but please help!
Message 1 of 9
Highlighted
Retired_Member
Not applicable
Re: Orbi not working after 5 months
I think Orbis are set to self destruct soon after 90 days. Almost everyone loves it at first and has no issues and then it becomes a brick causing more trouble than it's worth.
Message 2 of 9
Highlighted
Guide
A $300 brick??? Ugh. Is there no way to fix it? I can't even call them for support without paying!! 😡
Message 3 of 9
Highlighted
NETGEAR Moderator
Hello Mysesses
Are you able to connect using etherenet? Have you logged into orbi with www.orbilogin.net and then checked the wifi settings?
DarrenM
Message 4 of 9
Highlighted
Guide
DarrenM, I can't log in if I am not connected.
Message 5 of 9
Highlighted
NETGEAR Moderator
Can you connect a laptop via a wired connection?
DarrenM
Message 6 of 9
Highlighted
Guide
My daughter is out right now with her macbook but I am not sure it has any ports that can connect it anyway. Its one of those new ones that has the new ports on it.
Message 7 of 9
Highlighted
Guide
It is almost like our password isn't working. How can I change it without connecting?
Message 8 of 9
Highlighted
NETGEAR Moderator
Well the other option is to factory reset the unit and set it up again to do this just hold the reset button for 10 seconds on the back of the router.
DarrenM
Message 9 of 9
