Orbi WiFi 7 RBE973
Reply
Orbi not working after Modem Reset
andydallas
I set the Orbi up, Fantastic, no issues, easy to set up, geting 230M download on my laptop.
The next morning I had an issue with my modem and had to reset it.  Got it working, but now I have no WiFi.
I have verified the Modem is working (plugged desktop dirctly into modem, all is fine), but the Orbi is not.  Pulsing different colors, I think it ended up on Magenta,,,what do I do. I am ready to take it back (bought it yesterday)
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 4
Guru
Re: Orbi not working after Modem Reset
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s)
Message 2 of 4
andydallas
I simply went through the very easy setup process, I never changed anything
Message 3 of 4
Guru
OK.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1182 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
