Orbi WiFi 7 RBE973
Reply
Orbi not working well withmy samsung tablets
flyershigh
Follower
My Orbi seems to work very well,Except on mt Samsung Galaxy Tab S3 and mt Galaxy tab E.Does anyone else have this issue?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Guru
Re: Orbi not working well withmy samsung tablets
What FW are you currently using?
What channels are you using? Try using manual channels 1, 6 or 11.
What seucurity modes are you using? Try WPA and TPIK then try WPA2 and TPIK and AES.
Set up an IP address reservation ON the router for your devices.
Disable the following and see if it helps any: MIMO, Daisy Chain and Fast Roaming.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 780 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
