Orbi WiFi 7 RBE973
Reply
Orbi not working with switch between modem with other router connected
1162726
Follower
I am trying to create two seperate private networks. Currently I am using a switch between the ONT(we have FiOS) and Orbi. Whenever the other network is connected to the switch the Orbi reports that it can't connect to the internet. The issue may be our residential connection altough I think this setup should work. Currently i have the other router disconnected and the network is working fine.
Thank you in advance
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
ekhalil
Master
Re: Orbi not working with switch between modem with other router connected
You only get a single IP address from the ISP modem (ONT) so you can't put a switch there.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 817 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
