- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi overnight speed decrease
- Mark as New
- Bookmark
- Subscribe
- Permalink
Trying to figure out why wireless speed drops while logged off overnight. I routinely get 200+ MBPS all day through the wireless connection...however, after logging the computer off at night, then logging back on the next morning, speed is ~45 MBPS. Toggling the wireless connection at the computer off very briefly, then back on, speed returns to 200+. This is 100% repeatable.
Computer is a 2017 iMac, running OS Catalina, all software up to date. Orbi is on v2.3.5.30 firmware. Cable internet service, rated at 200 MBPS. When I log off the computer each night, it remains powered up and will go into sleep mode. AFAIK, the wireless connection remains after logoff, or else it reconnects each morning in some odd mode.
Didn't notice this until we recently switched to cable internet service and started doing random speed tests to confirm service integrity. Our previous ADSL service sucked (a miserable ~7 MBPS) so did not really have a reason to be testing speed until now. Any help is appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi overnight speed decrease
Are wired LAN speeds still good?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem is a Hitron E31N2V1 (supplied by internet provider), but I can't see how it would matter. The Orbi router handles all DHCP assignments, etc. and the issue is limited to wireless connection.
Tom
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the mfr and model# of this wifi adapter that the PC is using?
If you turn OFF The RBS, does the RBR show the same problem?
h
You might update to v16 on the system, factory reset and setup from scratch. https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-2-5-1-16-Update/m-p/1897955/highlight/tru...
