- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi pairing issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi pairing issue
When setting up the Orbi, I never got the LED Blue ring on the router. I did have it on the satellite. The signal from the satellite is stronger than the router. Does this mean that the pairing is not correct? Thanks for any suggestions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi pairing issue
Look at the firmware issue.
go to orbilogin.com
see if there is a sattelite.
if the firmware is 12.x then you may have to revert the firmware... or if recentlly purchased return unit to store
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello bager33s
Make sure that both devices are on the 1.12.0.18 firmware version and then it should just depend where you are in your house whether your devices will connect to the satellited or the main router.
DarrenM
