Orbi WiFi 7 RBE973
Reply
Orbi - random reboots
vanishevo
Guide
Hi guys,
Bought an Orbi around two weeks ago, everything was going fine until one week ago when the random reboots started.
It most recently rebooted just 40 mins ago, as is reported within the show statistics screen. System Up Time 00:41:39
Has anyone else ran into this?
BTW, I'm running firmware V1.8.0.6
Thanks
Chris
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 10
Accepted Solutions
vanishevo
Guide
Re: Orbi - random reboots
A quick update.. after swapping out the unit, everything now works fine!
Must have been a hardware issue.
The RMA process was very straight forward here in Australia, a replacement unit was sent out along with a return con note.. all too easy!
Message 10 of 10
All Replies
DarrenM
Sr. NETGEAR Moderator
Hello vanishevo
How often is it rebooting?
DarrenM
Message 2 of 10
vanishevo
Guide
Hi DarrenM,
So far, around every second or third day. The current uptime is 1Day 16Hrs, which is just before I made the post.
Some futher info around the setup: Router is in AP mode, patched into a brand new Telstra (an Australian Telco) supplied VDSL router.
Thanks
Chris
Message 3 of 10
DarrenM
Hello vanishevo
Have you noticed if you main router/modem is losing internet connection at the same times the orbi reboots?
DarrenM
Message 4 of 10
vanishevo
Guide
Thanks for the reply DarrenM.
Yes I've checked that, no issues to report with the internet connection.
For an isolation test, I've actually rebooted the router/modem and the Orbi flashes purple as expected, things go back to normal once the router/modem is back online.
Is it worth swapping the power adaptors between the main Orbi and the satellite?
Message 5 of 10
DarrenM
Hello Vanishevo
You can try that or even try plugging them into a different power strip or outlet.
DarrenM
Message 6 of 10
vanishevo
Guide
Hi Darren,
It just rebooted itself again, was plugged directly into the wall.
Have you heard of anything like this before? Sounds like I'll need to return it.
Thanks
Message 7 of 10
DarrenM
Hello Vanishevo
Yea you may need to exchange it or contact support.
http://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
Message 8 of 10
PDaddy
Guide
Happening to me as well.  Very irritating problem.
Message 9 of 10
vanishevo
Guide
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 3966 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
