Reply
Orbi rbk50 Router no internet but satelite does??
Cpawl
Follower
Got an orbi rbk50 router and one satellite last week, was working fine for a few days but now the router has no internet connection but the satellite has, have tried power cycles and reboots, any help with this would be great
Message 1 of 2
Guru
Re: Orbi rbk50 Router no internet but satelite does??
Is the Orbi system operating in Router or AP mode?
Turn OFF the RBS temporarily while troubleshooting.
Has a factory reset and setup from scratch been performed ON the RBR since last FW update?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M | XR1000 (Router Mode) and RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 242 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
