- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi rbk50 seems to be dead
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi rbk50 seems to be dead
What FW is currently loaded?
Try swapping LAN cables between the modem and ORbi router.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
If any of this fails, I recommend contacting NG support or return and replace the Orbi system for another. You may have a bad system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Prestong87 wrote:
........ Also when attempting to reset the orbi with a paper clip, no lights even come on, on the top of the router like its supposed to as if it's not responsive........
If no lights come up on the top of the router after rest then it looks like the unit is faulty.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Prestong87
Please hardwired a computer to the Orbi Router and check Local Area Connection / Ethernet Status. Does it say "Network cable unplugged"? "Unidentified Network"? "Connected - No Internet Access"? Kindly check as well if it has an IP address. Try accessing the orbilogin page, go to Advanced TAB > Statistics page. If WAN port status is blank then we could say that the router WAN port is defective.
Blanca
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Prestong87
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
