Orbi WiFi 7 RBE973
Reply
Orbi rbr20 remote management
Olivaman30
I had several netgear products registered between 2 email accounts. I had support merge them. When I upgraded my phone and downloaded the orbi app and tried to turn on remote management I got an error that the device is already registered to another account. I made sure my router was up to date and rebooted and still get error. Any help?
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 4
Guru
Re: Orbi rbr20 remote management
Has Remote Management been enabled on the RBRs web page by using a connected PC or laptop and web browser?
Message 2 of 4
Olivaman30
Yes. I did do that. I am able to login remotely through a browser. Just can't use the app.
Message 3 of 4
Guru
Try this, disable the Remote feature on the RBR, reboot the RBR, then re-enabled it once more on the RBRs web page. Then check the app. If this fails, Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 502 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
