Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi rbr20 up address issues with sats.
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-07-24
11:45 AM
2018-07-24
11:45 AM
Hi all, for some reason today our two rbs20 satellites have gone bonkers.
Both are fixed in magenta- purple and that seems to mean there is an up address issue! What could be the issue and any tips on how to resolve would be great.
Thanks all.
Thanks all.
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-07-24
12:01 PM
2018-07-24
12:01 PM
Re: Orbi rbr20 up address issues with sats.
I would disconnect everything from the router, wired and wireless devices, accept for 1 wired PC.
Turn off the satellites.
Reboot the router.
Turn on 1 satellite and see if it will re-connect with the router and the top led will turn on BLUE. IF so, use the wired pc and a browser and log in to the routers web page and set up an IP address reservation for the 1 satellite. Save and apply.
Turn on the 2nd satellite and do the same.
If the satellites will not reconnect, try a reset on 1 satellite and then try to re-add it. IF you can, do the IP address reservation for the satellite. Do same process for 2nd satellilte.
Message 2 of 2
Announcements
