Orbi WiFi 7 RBE973
Reply
Orbi rbr20 will not connect to internet
BellaNZ32
My Orbi was working fine and then it started dropping the internet intermittently. Unplugging it and plugging it back in seemed to work for a while but now it doesn’t as the internet keeps showing as offline. The modem connects, just not the internet. I tried a hard reset twice but has not worked. There are no other modems/or routers connected.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 16
Guru
Re: Orbi rbr20 will not connect to internet
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Has a factory reset and setup from scratch been performed since last update?
Message 2 of 16
CrimpOn
Guru
What version of firmware is on the Orbi ?
Message 3 of 16
BellaNZ32
Firmware is V2.3.5.26, I connected the orbi via my old ISP router (which I unplugged again now....internet works fine with that one) and then I logged into orbi online and checked for new firmware, nothing was available so I assume I have the latest.
Message 4 of 16
BellaNZ32
I’m not connecting via the ISP modem as it’s also a router and messes with the mesh WiFi signal, the Orbi Internet port is connected directly to my fibre box which are right next to each other
Message 5 of 16
BellaNZ32
House is about 260 square
Satellites are a good distance apart
I think I am using auto, not sure where to check this or how to change it but while playing with things for about 5hrs I saw a lot of auto settings
There’s only one neighbor within range showing as another WiFi connection option
The factory reset was set up from scratch has just been done, twice
Message 6 of 16
BellaNZ32
V2.3.5.26
Message 7 of 16
Guru
So i you have a router in front of the Orbi RBR, you might try changing the RBR to AP mode instead of router mode. Having to routers on the same line can cause problems.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
What is the Mfr and model# of the ISP modem?
Message 8 of 16
BellaNZ32
No I don’t have the ISP router turned on, I just plugged it in to see if there was an issue with my external line or ISP fibre connection. it worked fine so must be the Orbi. It’s disconnected now as the Orbi has been fine (until now) without running through the ISP modem/router I assume I don’t need it plugged in or bridges as the Orbi should just work like it was before?
The ISP modem is a Vodafone Ultra Hub plus.
Message 9 of 16
Guru
Your Voda Phone modem does have a built in router. To make this work well for the Orbi router, try the #2 suggestion in the list of options I gave you to see if this helps the Orbi router work in router mode. If not, then configure the Orbi RBR for AP mode as suggested in #3.
I think you need the modem as a interface with your ISP service unless you have a interface with the ISP service that has a RJ45 LAN port on the ISP device/ONT.
I recommend you contact your ISP to see if this Voda Phone modem is required or not. Then go from there.
IS this your modem that you are using from the ISP?
https://www.vodafone.co.nz/cms/documents/ultra-hub-plus-quick-start-guide.pdf
Message 10 of 16
BellaNZ32
Ok - I will give that a go, I did ring them last night and they said don’t use a third party router, I said there’s has crap coverage and extenders are useless but they simply said don’t use other routers. Hopefully get someone else who is more useful today.
I just plugged the Orbi directly to the fibre box , followed set up instructions and it worked
Yes that link is the ISP modem I have
I did have it running directly through to the fibre box up until yesterday but it did start dropping out maybe once or twice a week
Don’t know if I’m matters but I have a cable running from my Orbi to a mini switch as I have Ethernet cables from switch to a few devices that are hardwired in
Message 11 of 16
BellaNZ32
Vodafone technical help is not helpful, the modem settings does not have a bridge mode option, and voda tech advised that they do not support making this switch over and I’d need to get a technician out to put it into bridge mode, I read online there is an admin login to Vodafone routers and you need this to do it.
Message 12 of 16
Guru
Ok, sounds like the Voda Phone modem isn't needed then.
Now we are getting more info. So there is a switch between the Fiber unit and the RBR? If so, I would directly connect the RBR to the Fiber device and put the switch behind the RBR. You maybe running into problems having this switch in between the Fiber device and RBR. It's not normal configuration to have a switch before the RBR. Connect it after the RBR and see if this helps.
Is this switch something setup by you or the ISP service? Do you have any TV services with the ISP?
Message 13 of 16
CrimpOn
Guru
Can you provide the brand/model number of the fiber box?
Message 14 of 16
BellaNZ32
The RBR is connected directly to the Fibre box and then there is a connection from the RBR to the switch
Switch was set up by a non ISP tech, no tv services with the ISP
Message 15 of 16
BellaNZ32
The Fibre box is a “Optimal Network Terminal” that is installed by Chorus, all Fibre installations in New Zealand are carried out by chorus so must be the standard install that everyone has.
Message 16 of 16
Top Contributors
Discussion stats
  • 15 replies
  • 4134 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
