Orbi WiFi 7 RBE973
Reply
Orbi rbr40 ssid and password
sccadwell
I reached a point in the installation where I had to join my new Orbi's network - listed on the sticker under the device as "Orbi13." This network did not show up on any of my WiFi devices, and I was unable to continue the installation. The plug-in satellites did sync with the base router and showed blue LEDs which turned purple when the base was turned off. A mysterious new network appeared on my iPhone while the Orbi was powered up, but I was unable to join it. It appears to me that Amazon sold me a returned system where the original owner changed the SSID and password. Is there any way to fix this, or am I better off shipping everything back to Amazon?
Message 1 of 7
Accepted Solutions
CrimpOn
Guru
Re: Orbi rbr40 ssid and password
If Amazon sold you a returned system, then the previous owner may have changed the Administrative login password as well as the WiFi name (SSID) and password.  Time to get out a paperclip, unbend it, and stick the end into the tiny "Reset" hole on the back of the Orbi near the power jack.  Hold it in until the power LED turns amber and begins to flash (about 10-15 seconds).  At this point, the Orbi will be returned "to factory", which means the WiFi SSID and password will be what is printed on the label and the Administrative password will be "password".  Good LUck.
Message 3 of 7
All Replies
Guru
Use a wired PC and web browser and log into orbilogin.com or 192.168.1.1.
Setup a new and custom unique SSID name and Password. Save the change. Give about two minutes. Check with one of your wireless devices to see if the SSID name you set appears. If not, the system is bad so return the Orbi system and ask for another system.
Message 2 of 7
CrimpOn
Guru
Message 3 of 7
Retired_Member
Not applicable
What IF the label has been removed?
Message 4 of 7
CrimpOn
Guru
Orbi's come with two labels.  One is plastic wrapped around the case.  The "real" label is on the bottom of the case.  Hard to imagine anyone removing it.  Here's a picture:
Message 5 of 7
sccadwell
The reset did the trick. My router still has all of its relevant stickers.
Thanks to everybody for their suggestions!
Message 6 of 7
Guru
Thanks for letting us know. Glad the reset worked. Unit stickers are usally not removed by owners. There there for a reason. Smiley Wink
Enjoy. Smiley Very Happy
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2287 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
