- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi rbr50 router Wifi does not work but satellites do
- Mark as New
- Bookmark
- Subscribe
- Permalink
connect to the internet when they are in close proximity of the router. Any help or pointers would be really helpful. Thanks in advance!!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi rbr50 router Wifi does not work but satellites do
Thank you so much for the advice!! I had to set 20/40Mhz Coexistence to 40Mhz only and set Short preamble instead of Long preamble. Rebooted and the dead zones with the iOS devices are gone! Thing of the past. Thanks a lot!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good to hear.
Please mark your post thread and solved.
Enjoy.
