Orbi WiFi 7 RBE973
Reply
Orbi router [RBR50] and 2 Orbi satellites [RBS50] in a Daisy chain limits?
n19htmare
Dear Netgear,
How many satellites can you Daisey chain. Currently I have two and am wondering if the following scenarios are possible:
a- buy one extra RBS50 and have Router > sat 1 > sat 2 > sat 3.
b- buy one extra RBS50 and have Router > sat 1 > sat 2  AND  Router > sat 1 > sat 3.
c- buy two extra RBS50s and have router Router > sat 1 > sat 2 AND Router > sat 2 > sat 3.
Has anyone any experience of this configuration?
Kind regards,
Tristan
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Orbi router [RBR50] and 2 Orbi satellites [RBS50] in a Daisy chain limits?
The wireless backhaul allows many possibilities. But each jump in the node is going to add some latency. If its possible, here's how I'd do it.
Sat 1<------sat2<--------Router---------->sat3---------->sat4
This would only be a single hope, daisy chain setup. Sat 1/4 still get a little extra latency but not bad. Kind of a combination daisy chain/star configuration.
I've never ran more than router------sat1------sat2 setup because my home isn't large enough to need another satellite at the end and its worked well.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 366 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
