Reply
Orbi router bricked (RBR50)
madbrain
Luminary
So, after doing the 4th factory reset and manual firmware rollback to version 1.11.0.20, my router is apparently bricked.
This is the most consistent state that my Orbi router has ever been. The white light just blinks immediately on power on; factory reset (inserting a pin) has zero effect ; no network activity whatsover.
It's only marginally less useful than it was before.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 13
martyfp
Luminary
Re: Orbi router bricked (RBR50)
sorry to laugh but that's funny !
Message 2 of 13
DarrenM
NETGEAR Moderator
Hello madbrain
You will need to contact support
Please contact NETGEAR Support at 1-888 NETGEAR (638 4327) if you have any questions.
 http://www.netgear.com/support/contact.aspx
DarrenM
Message 3 of 13
madbrain
Luminary
I have tried. No luck getting an RMA in 3 calls.
At 4am PT, I was put on hold for 45 mins, never got to anyone who could get me an RMA, only open a case (28816243).
I called again at 3:20pm PT, got disconnected after 10 mins on hold.
I'm on the third call now and being transferred again and on hold .
I keep getting told I was misrouted to the Netgear home department, when really all I did was enter 2 for RMA rather than 1 for support on the voice prompts.
It doesn't seem like 24 hour support is really there.
Message 4 of 13
DarrenM
NETGEAR Moderator
Hello madbrain
I sent you a PM
DarrenM
Message 5 of 13
madbrain
Luminary
Thanks. I'm still on hold with support since my last post ...
Message 6 of 13
madbrain
Luminary
And still on hold. Over 2 hours on hold combined so far, no RMA still .
Message 7 of 13
madbrain
Luminary
And of course disconnected at 1 hr 9 min on hold ...
What does it take to get an RMA ?
Message 8 of 13
madbrain
Luminary
Tried yet again, caller 97 in queue, expected wait time 40 mins . Sigh. Can't afford to wait this long. Why isn't there an online process to get an RMA ???
Message 9 of 13
st_shaw
Master
If I were in your position I would try to use tftp to manually reload the firmware. There are instructions somewhere on the Netgear site.
Message 10 of 13
madbrain
Luminary
The Orbi router device does not acquire an IP address from my R7000 router. There is nowhere to tftp to .
Message 11 of 13
st_shaw
Master
The beauty of this method is Orbi doesn't need to acquire an IP address from your router.  I've used this a couple times to recover a bricked Netgear router.  I've never done this on Orbi, so I cannot guarantee it will work. It's something to do while you're on hold for 2 hours though. Smiley Happy
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
Message 12 of 13
madbrain
Luminary
Thanks. I tried that procedure, but it just doesn't work with Orbi .
I also looked at the network traffic with Wireshark . When my PC is directly connected to the Orbi, no packet originates from any other MAC address but my PC's NIC  . Unfortunately, I believe the Orbi router is really bricked.
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 3294 views
  • 2 kudos
  • 4 in conversation
Announcements
