- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi router cannot be found after factory reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
Few days ago I have upgraded my ORbi RBK sistem to the latest firmware. The system worked OK but in the device list was only 2 devices from 10. After that I have done factory reset of the router and now I cannot connect to the router again. I have a white pulsing LED. I have tried factory reset many times with paperclip pressed on hte reset buton until amber LED was flashing and still no success.
Looks like the configuration is missing.
When I switch ON the power, the LED above power connection is green.
I have tried also manual IP 192.168.1.10 on the PC and still nothing.
There is no any wi-fi network broadcasting.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe I did not explain myself more clear as english is not my first language but the problem was that after firmware upgrade and after factory reset, the router RBR50 was not accesible anymore by any way.
I was asking if there were any way to access the router like safe recovery mode or something like that and... I founded here
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
very easy... and now... working
Thank you for your time
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi router cannot be found after factory reset
It might help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
Where did 192.168.1.10 come from? Do you mean 192.168.1.1?
After playing around with things, be sure to restart your network in this sequence:
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still no connection.
Already done all as suggested.
Is there any way to force IP or to change the firmware? I know that can be used telnet connection but only if there is telnet activated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@silvinnio wrote:
I am using orbi router rbk50 as modem with PPoE connection.
The RBK50 is a router/satellite (RBR50/RBS50) combination.
It has to get the Internet from something. A modem, optical termination, something else.
What have you got plugged into the yellow (Internet) port on the RBR50?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@silvinnio wrote:
....but the problem is not related to the internet connection. The RBR50 cannot be seen, no any wifi or wired connection.
There is a logic jump in there.
But as you seem to have worked out where the problem is – I am not convinced – I'll leave you to work out your own answers.
I'm surprised that no one else has stepped in. Maybe they are as puzzled as I am.
- Mark as New
- Bookmark
- Subscribe
- Permalink
