Orbi WiFi 7 RBE973
Reply
Orbi router keeps going offline and rebooting
Geebs21
Follower
The orbi router keeps going offline and rebooting several times a day. I see this has happened before. I had no issues until the firmware was updated.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Orbi router keeps going offline and rebooting
Power OFF the ISP modem and RBR for 30 seconds, then power back on the ISP modem and let it sync then power ON the RBR.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3327 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
