- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi router suddenly lighting majenta
- Mark as New
- Bookmark
- Subscribe
- Permalink
My router suddenly lit up majenta. I have tried disconnecting and restarting but still lighting up majenta. Other things are plugged into my router (AT&T Uverse) ethernet connections and they are working, just not the orbi. I've rotated the ports but no matter which ethernet port I use for orbi, it won't light white. It actually blinks white for a bit but then comes up majenta. Thoughts???
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi router suddenly lighting majenta
Hello Adrianrod
You should have it connected to the WAN port when connecting it to your modem also do you have your ATT modem bridged or if not do you have orbi set to AP mode?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I have it plugged into one of the local ethernet ports. Not sure about it being bridged. Its been about 6 months since I originally set it up. I had a power outage a couple weeks ago and it hasnt come back since.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the power knocked it out you may want to contact support if the unit is under warranty.
http://www.netgear.com/support/
DarrenM
