- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi satellite disconnecting intermittently
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi satellite disconnecting intermittently
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Have you factory reset the Satellite and re-added it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how it turns out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here is the update - so I just got the satellite replaced from the authorized support center here last week. It wasn't any better than the old one, the local support suggested to change the router setting region to "America" (original default was Europe; I'm actually located in Hong Kong) - he said somehow this normally gives the best signal in Hong Kong. Seems he is right - it has been 2 days the disconnection problem not occuring (previously the disconenction happened at least 7-8 times a day so this is pretty obviously) - hopefully this will last and not just out of luck this week.
Thanks again to all who attempted to help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it figured out. Odd that regional settings impacts operation and performance.
Enjoy.
