- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi satellite dropping connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi satellite dropping connection
That's a cop out imho
I've heard that in many of the multitude of threads reporting this disconnect issues
I have no Google Pixel phones or devices - nor do I have any android devices but I get all the same symptoms and experiences of random dropouts, occurring with random frequency and persistence - sometimes 10-30 minutes others times hours
This is a problem with all orbi devices - occurs in the "business" version and no solution in site running the latest firmware V2.1.4.16
- Mark as New
- Bookmark
- Subscribe
- Permalink
Looks like this is a persisting issue with the Orbi system. I've tried resets, different firmware, etc, and nothing seems to fix the disconnects. My orbi satellite starts up, connects, shows a blue connection, and then innevitably drops the signal for a minute or so before re-finding the blue signal strength. This is unacceptable for such an expensive "mesh" system. My base and hubs are not that far apart, maybe ~20 feet - all show good connections. I'm going to try one more test today... base and hubs in the same garage. If the signal continues to drop when the hub and satellites can actually see each other, then I'm going to return this POS to Best Buy and try a different brand. People on here say they have luck switching from Orbi to TP link Deco, Eero, and the google system ... there's no point in spending hours trouble shooting with Netgear when other systems work out of the box, and this problem seems to be present regardless of the firmware version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also, I must mention, the early messages in this thread received multiple netgear responses with "PM me", but without any attempt at a public solution. Why can't the Negear support staff on here actually help within the forum? All of these private message requests from Netgear staff make it seem like Netgear doesn't want this problem openly discussed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
FYI This is not a Wifi sync problem since both of my satellite devices are hard-wired connected - this is a software issue
Does not matter how close or far your satellite systems are they will disconnect even when connected via Cat5e cable back to the rbi main unit
All this adds up to a problem with software/firmware and not a physical location issue or even a wifi connectivity issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wow, thank you for doing the heavy lifting here. Been these exact issues this starting about a week ago, driving me nuts! At least now it seems Orbi is the cause.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried a factory reset on the setellilte first after the FW update, then re-add it?
Might try a full factoy reset on the router and satellite as well the set up from scratch and see if the problem continues.
Try setting manual channel 1, 6 or 11 on the base.
Disable MIMO, Daisy Chain and Fast Roaming on the base and reboot.
What is the distance between the base and satellite? Feet?
@Mcguyvr wrote:
Wowsers. Same issue. Works for 10min maybe 30min then satellite drops connection to 1% of previous signal strength. All kids kindles and iMac start showing WiFi with exclamation marks. All this started to happen when I blocked a couple devices then did a firmware upgrade check (now on 2.1.4.16). Wish I never tampered with anything. Now kids internet pages say they are still blocked even though they are not in the Orbi app on my iPhone. Not a wireless techie here but dropping half my homes devices only to have to reboot or resync satellite for another 10mins of internet is the crappiest thing I’ve ever experienced. So frustrating and my triplets are going insane without internet. The router appears unaffected and 2 wired devices appear unaffected. I don’t have time for hours of t/s and phone support. Is there a way to roll back firmware or just send me a new satellite will ya?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Use a wireless or wired PC conntected to the router and log in to the routers web page and make changes there.
@Mcguyvr wrote:
Doing factory reset now. I’m on the new network I set up after factory reset but only on the main router. Not sure how to make the settings changes you mentioned above(fastbeam, mummies etc) . Will have to research that as I’m not finding them in the APP on my phone. Should I try to add the satellite first (I skipped that at setup) before altering the above suggested settings?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you move the satellite farther out? 20 feet is a bit too close. The router can cover around 30feet depending upon building materials. Mines at 40 feet as crow flies, two walls and a roof in between mine. LOL.
@Mcguyvr wrote:
Thanks. Found it. The satellite somehow auto connected even though I said skip. Distance is only 20ft as crow flies just down an open stairwell. Did I mention it all worked fine since feb. well....it is using daisy, and...so far it has worked the rest of the day. I won’t hold my breath ....will update tomorrow if still going without drops...I made no other mods to setting aforementioned. Appreciate the replies. Will let ya know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also pleast try testing with the satellite turned off and your PC connected to the router. Let us know if you see same problem or not. if not, I recommend that yout get in contact with NG support and ask for an RMA.
@Mcguyvr wrote:
Well did it again. No mi-mumu, no beamforming...just surfing for 20mins YouTube on the iMac and wham...crawl to 0.03-.10 mbps. When I reboot the pc, it reconnects again for the short while. Then the satellite appears to drop again. I’ll try with beamforming on and mimu on. But I think there’s some hardware issues with the satellite.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I gave up as well. After reinstalling, resetting, downgrading, upgrading etc. for too many times, I bought a google wifi and - since then on google wifi - everything is running very well. No more disconnects, no more lost satellites, no more wondering if it's my ISP. It has been the Orbi system malfunctioning in unpredictable ways all along. An extremely disappointing Netgear experience overall and I will not buy from this company again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been seeing a couple droped connections. what I have found is my SBR30 sattlite keeps changing 192.168.0 instaed of the base 192.168.1. The dropped device is 192.168.0
If I go to an area where the 192.168.1 base is and turn my wifi back on it picks up the correct IP and woks fine. I have use fixed IP and this helps but not the solution. Does anyone have any ideas why I'm seeing this behavior?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
What firmware version is loaded on the Orbi router and satellite?
What is the Mfr and model# of the IP modem the Orbi is connected too?
Do a factory reset on the satellite and re-add it to the router.
What is the distance between the satellite and Orbi router? 30 feet is a good starting point.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Any other wifi nieghbors near by?
Besure your satellite is connecting to the Orbi routers wifi.
Is the Orbi router using 192.186.1.1 or .0.1 for it's host address?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m sure your suggestions may help some. But, it does beg the question why should any Orbi user have to go through this sort of process? Most users are probably not that computer savvy let alone wireless router experts. Netgear needs to once and for all write firmware that works and works consistently. A $400+ system should work out of the box.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I agree, the systems should work. However we are here in the forum to help figure out what isn't working and try some suggestions to help get users systems going and working better. Until NG figures all of this out, all we can do is to help. We try to be as detailed for those users who are not adept in working with there gear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I seemed to have corrected most of my issues by moving my 2nd satellite further away from the base and allowing it to daisy chain through the 1st satellite. I haven't seen any drops in the past few days. My original issue might have been due to the second satellite sometimes connecting directly to the base and sometimes daisy chaining; seems like the connection would drop when switching back and forth.
- Mark as New
- Bookmark
- Subscribe
- Permalink
30 feet in between router and satellite(s) and in between each satellite is a good starting point.
- Mark as New
- Bookmark
- Subscribe
- Permalink
All of these steps are irrelevant in my experience - I have back channel connected devices and they still disconnect and the whole system goes down
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yo may have other problems. Maybe your system needs to be replaced. I would contact NG support and ask for an RMA.
Others are not having wired back haul issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
