- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi satellite flashing and not pulsing white
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought another Orbi RBS 50 to work with my existing system. I have an existing Orbi router and one satellite and wanted to extend the WiFI system in my house. As soon as I connected the new Orbi satellite it began to flash white instead of pulsing white. It proved impossible to connect to the router. Any suggestions would be gratefully received. I am no tech wizard so basic advice would be appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi satellite flashing and not pulsing white
FW on the new satellite needs to be updated first:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-Satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your prompt response. No problem downloading the information to update the firmware for the new satellite but as it has not connected to the router when I go to manual update it will only display the original satellite Orbi. I note that the new satellite Orbi is running on V1.12.0.18 and my system is running on V2.1.4.16 but how do I get the firmware to update when it willnot display.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You'll need to manually download the FW update files to your PC.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have already downloaded the correct FW on my computer but how do I now transfer it to the RBS50 if I cannot download it manually via the management site?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello @flamenca,
Please follow these steps and let me know if you run into the same issue.
~Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Christian
Thank you for the info. No problem following the directions to download the upgrade but as the new RBS50 is not acknowledged as being connected there is no box to indicate conduct a manual download. I have read that the only way to update the firmware for this problem is to do it directly via TFTP. But How?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
@flamenca wrote:
Hello Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi -- I'm having the same problem (have posted a new thread, sorry for the cross-post).
I've found the Netgear page on how to upload the firmware to the satellite (https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client); the only problem is that the link given for the TFTP client doesn't work (i.e., the link in the instruciton "2. Download and install the Tftpd64 software from: TFTP Client" is invalid).
Could anyone help? Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try using the TFTP client thats built in to Windows. Others have said the one that NG provides doesn't work right.
- Mark as New
- Bookmark
- Subscribe
- Permalink
why do you post unnecessary answers? Do you just want to increase your reply counter? it's the built in client that does not always work ...
PS when quoting something it's best practice to answer below the quote not above
regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
I posted so that users can try both methods. Users have said the built in client also works which had not been mentioned here.
Thank you.
regards
