Orbi WiFi 7 RBE973
Reply
Orbi satellite will not connect to my router
Nyfireman3097
I set my orbi and satellite 2 days ago. It was fine then last night and all day today the satellite stopped working. I opened the app checked for satellites and none found. I try to connect it got the blue ring and nothing. I suck at computers for the most part so any advice would be huge. I have the few 12.0.18 on the router
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 6
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: Orbi satellite will not connect to my router
Hello Nyfireman3097
Do you happen to have a special character or space in your wireless password this is a known bug to make satellites disappear. If not you could try to factory reset the satellite and re sync the unit.
DarrenM
Message 2 of 6
All Replies
DarrenM
Hello Nyfireman3097
DarrenM
Message 2 of 6
Nyfireman3097
Thanks Darren I actually did I factory reset I and took the space out and it's working great thankfully 👊🏼
Message 3 of 6
justSomeone
Wait... I missed the notice that a SPACE or special character is causing all this wonkiness with 12.x
Why is this not an PINNED message at the top of the forum?
Message 4 of 6
DarrenM
This issue will also be fixed in the upcoming firmware.
DarrenM
Message 5 of 6
gbjackson
Apprentice
So, could you bop down to the long thread regarding 1.12 firmware and provide an update on the new release?  Thank you.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 9067 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
