Orbi WiFi 7 RBE973
Reply
Orbi satellites stopped showing on app and website
vipers2314
Follower
Hello ,
If anyone can help me i would be very grateful . I purchased an ORBI mesh system consisting of RBR50 router and 3 RBS50 satellites . Everything was working fine until a week ago i noticed that the satellites shows red in the phone's app , 0 connected satellites . On the web i can see that i have 2 connected satelittes and the 3rd is off . I removed it and tried syn again but it dosen't show anymore . I think it does sync with my router since i get the solid blue at the end however no proof of it in the apps and web . It is very strange , i do have the interent connection and i didn't change any placement . I am confident that the system is working fine however the app and website are showing false information . How do i fix all that and get them showing again in the app ?
Thank you in advance
Elie
Message 1 of 2
Guru
Re: Orbi satellites stopped showing on app and website
Please try a factory reset and setup from scratch with the RBR and RBS.
@vipers2314 wrote:
Hello ,
Elie
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 249 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
