- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi setting up backhaul with spectrum
- Mark as New
- Bookmark
- Subscribe
- Permalink
my system Spectrum internet with Arris TM1602A MTA cable modem. RBR50 RBS50 and an RBS40
I am trying to get a morfe stable system and am looking at setting up wired backhaul with the orbi. can be very confusing... What settings for the orbi do I need to set in the advanced setup section. I have updated to the latest 2.3 firmware. do ineed to setup any thing different with the Arris. Today the orbi is set to router mode should i be in AP>? all suggestions appreciated thanks gegger
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi setting up backhaul with spectrum
The ISP Modem is a modem only so the Orbi can run in router mode.
A recommended way is to use the Orbi Base routers web page to help setup satellites using a connected PC and web browser.
Do the following in the same room as the Orbi base router:
When connecting the satellites via wired back haul, connect 1 satellite first via wireless, then once you get the BLUE led on top of the satellite, connect the LAN cable between the satellite and Orbi router. Wait for up to 5 minutes for the top LED to turn BLUE. Once this is done, do a IP address reservation for the satellite ON the Orbi router. Save and apply.
Connect all follow on satellites using the above method.
Once all is connected and running. Place satellites in remote locations with there LAN cable connected and turn ON.
Be sure that Daisy Chain is disabled on the RBR when you have the satellites connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know if you were able to get this setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’ll be working on it this weekend have to fish a couple cat 6 cables. What about a static ISP for router an satellites - regardless I will report back
- Mark as New
- Bookmark
- Subscribe
- Permalink
I use static IPs for all of my satellites -- and those are .7, .8 and .9. My DHCP range starts at .10
Works very well. You will enjoy that wired backhaul.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can use reserved IPs for satellites ON the router. Static isn't supported ON the satelites themselves. Reserved IPs is recommended for satellites. Keeps them connected at a particular IP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recommend each satelllite connect directly to the base router. You can connect them daisy chain wired I believe, however if the in between satellite happens to experienece problems, this may effect the down stream satellite. So I would avoid this possibilty by direct connect each satellite to the base router for independent operation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
One last question I’m tech inclined but this is new to me. So I set up backhaul do you reccomend static ip for the router and the satellites. If so what do I use for the ip. Do i set the ip prior to syncing the satellites
- Mark as New
- Bookmark
- Subscribe
- Permalink
Lets use IP address reservation. This would be set ON the router after the satellite(s) have been connected to the base and are up and running. You can use what the router assigns to the satellite after they are connected.
Static IP addressing is set ON devices and involves being out side the routers IP address pool.
These are general normal networking nomenclature.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know if there is another disconnect again after the factory reset and setup from scratch.
Has the ISP modem and RBR been powered OFF for 1 minuted then modem back ON then power ON the RBR?
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes I unplugged for at least a minute and did the sequence modem power up followed by router
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok, Lets see what happens since you've done a reset and setup.
When you updated FW, did you reset and setup again or just apply and continue wiht out a reset?
- Mark as New
- Bookmark
- Subscribe
- Permalink
i did a full reset and setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, lets track this and see how far it goes.
Haven't seen anyone else with issues with the ISP modem since v32. Mostly configuration issues and wifi speeds.
If anything, can revert to v210.
- Mark as New
- Bookmark
- Subscribe
- Permalink
bacul is wired and running - still need to setup reserved ip address for the router and satelittes. erlier you said to turn resrve IP on i can find it give me soe guidance thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
BAck haul set up everthing seem to be fine, then router shut down. did a factory reset got it back up. still need to reserve the ip address. still undure where i go to reserve an ip
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
an update ic ould never get teh routher to hook up. I factory reset, looked at setting up as a new system and nothing its now piled up with the RBS50 and the now useless RBS40. I have reinstalled google wifi, speeds are slower but every thing that needs speed is is direct connect _ at least im stable
