- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi setup as Router or AP?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just purchased the Orbi and was wondering what the best setup is? I have a Ziggo modem/router. Should I setup the Orbi as router (Ziggo in bridge mode) or as AP?
Thanks in advance for your replies.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is no right or wrong answer. If you like your Ziggo's router features, then use Orbi in AP mode. If your Ziggo modem/router has bridge mode, then you have the option to use Orbi in router mode. I use my Orbi in AP mode because I have another router with better routing features and no WiFi.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi setup as Router or AP?
@TomiPhone wrote:
Hi there,
It depends on which device (Orbi or Ziggo) you think has better router functionality.
If you set Orbi in AP mode then you will not be able to benifit from Orbi features like DDNS, VPN, UPnP, Access Control/Circle, ...etc. If you think that you can get equivalent or better functionality from Ziggo then set Orbi in AP mode, otherwise Router Mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
