Orbi WiFi 7 RBE973
Reply
Orbi slower than Xfiniti router
stevedavis
Just had our internet fixed as the outside booster was bad.  We were running 75 down and .5 up.  After the fix, did a wifi test and the xfiniti router ran at 475 down and 18 up.  Put it in bridge mode and hooked up the orbi using a Cat 6 cable.  175 down with 17 up.  Both in the same spot.  Xfinity router has always been used in bridge mode.   Any thoughts as to why?
Message 1 of 8
Accepted Solutions
Guru
Re: Orbi slower than Xfiniti router
Make a back up configuration to file for safe keeping. This saves time if a reset is needed.
AP Mode Reference:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Please mark your thread as solved.
Enjoy. Smiley Wink
Message 8 of 8
All Replies
Guru
Power OFF the modem and RBR for 1 minute then back ON with the modem then RBR. Wire connect a PC to the RBR and speed test.
Has Armor or Circle been enabled?
Message 2 of 8
stevedavis
Firmware   V2.5.1.16
Comcast modem TG3482G
Roughly same speeds after reset
Did not acitivate armor or circle
Message 3 of 8
Guru
And you are sure the modem has been fully bridged? Not just disabling the wifi radio on the modem...this doesn't count. Smiley Wink
One thing to try out, put the ISP Modem back to router mode and then configure the RBR for AP mode. Leave the RBS OFF for now.
Message 4 of 8
stevedavis
I just used the Bridge mode enable/disable button on ISP router.  Is there something else I need to do?  I did have the Orbi in router mode for wifi.  Will try it in AP mode later today and let you know.
Thanks for your help
Message 5 of 8
Guru
Ok just checking. One other thing to do would be after the bridge mode has been enabled and applied, power OFF the modem and RBR for 1 minute then back on.
Message 6 of 8
stevedavis
AP mode wouldn't work at all and I'm sure it's user error in the setup.  Updated both the Orbi (now in router mode) and satellite firmware though I thought I had it set up to update automatically.  Now it's running 450-500+ down and 13-15 up (few notches slower than the ISP router).  Did notice that more devices are connecting to the satellite than before so I'm assuming the firmware upgrade helped. Will leave well enough alone now.
Thank you for all your help and suggestions.
Message 7 of 8
Guru
AP Mode Reference:
Enjoy. Smiley Wink
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2432 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
