Orbi WiFi 7 RBE973
Reply
Orbi speedtests showing higher than other apps
ThePablo
So I’ve been noticing as of late that when running the included Speedtest within the Orbi app I consistently get 114mb, but am running the app by Ookla and get 8-10mb. Why such the difference? Aren’t they both testing the same thing, or is the Orbi one not checking actual internet. Confused. Thanks for any help.
Message 1 of 9
Accepted Solutions
tucsontico
Virtuoso
Re: Orbi speedtests showing higher than other apps
Not sure why the built-in test shows a higher number but I do know that using the built-in Speedtest has caused problems with Orbi for some folks. Several threads recommend NOT using the built-in Speedtest due to WiFi anomolies showing up after running that test. I'm still running firmware 2.0.74 and NEVER do a Speedtest from Orbi's built-in. I would not trust the built-in numbers. Cannot say if latest firmware solved this issue.
Message 2 of 9
All Replies
tucsontico
Virtuoso
Message 2 of 9
ThePablo
Thanks for the tips and suggestions of not running in-app.  I confirmed I am using 2.0.74, so I just rebooted my network and will continue to keep an eye on the connection.  I will validate, and possibly restart my cable router as well.
Message 3 of 9
tucsontico
Virtuoso
If you connect directly to your modem (no router) what download speed do you get?
Message 4 of 9
ThePablo
With an ethernet connection?  I haven't tried that, but I definitely will.  I've usually had pretty decent numbers, but again, I've only ever done them using the Orbi speedtest, so maybe in fact I haven't.  I will begin going back to the Ookla app for my speedtests.  I should have known or at least been questioning things, when for the life of this network (July '17) I've only ever gotten a reading of 114mb from the Orbi speedtest app.
Message 5 of 9
tucsontico
Virtuoso
Just thought of one more thing: Be certain your measuring the same values. Sometimes the speed tests are reported in megabytes (MB) versus megabits (Mb)
Message 6 of 9
ThePablo
Thanks, yes, definitely comparing apples-to-apples.
Message 7 of 9
tucsontico
Virtuoso
Definitely do a direct connectvia ethernet to your modem to see your "true" download speed. Remember, the speed will change depending on the upstream load from your ISP. The advertised speed is a theoretical maximum and not a static value.
Message 8 of 9
ThePablo
So I tried the hardwire vs wifi, using speedtest.net, and very simliar speeds.  I will continue using this site or app on my iPhone and no longer use the in-app version of the speedtest as suggested.  Thanks for the tips.  Posted the details below, the earlier one in the day is wifi and latest via ethernet.Screen Shot 2017-12-09 at 3.50.44 PM.png
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 5193 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
