- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi stopped working with ethernet switch
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an Orbi RBK50 system with 2 satellites. Some devices are connected to the router using ethernet and a Netgear GS308 unmanaged ethernet switch.
Until yesterday, everything worked fine. Now, however, devices connected via the switch don't receive an IP address from the router and thus cannot connect to the network. The devices can detect they are connected by ethernet, but that's as far as it goes. If I connect them directly to the router via ethernet or WiFi, they can connect fine.
I have not changed any of the settings in the router or any of the devices and the router is running the latest firmware.
I have tried:
Replacing the switch
Changing the ethernet cables
Factory resetting the Orbi system
None of these have fixed the problem.
I'm out of ideas and call upon the wisdom of the community in the hopes of a solution.
Thanks in advance for any help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi stopped working with ethernet switch
My first thought would be the switch. But since you swapped out the switch with a known working switch, I would now check the cable coming from the Orbi to the switch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Zaichik wrote:
Thanks. I've tried changing the ethernet cable with a couple of others that I know work elsewhere in the house. Still no dice.
What happens when you bypass the switch and plug one device's cable directly to the Orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Zaichik wrote:
As noted in my original post, if I connect the devices directly to the Orbi's ethernet ports, they connect fine. Everything points to the switch being the issue so you would think that changing the switch would have fixed things. That's why I'm so baffled.
Let me rephrase, do you have internet connection when you connect the exact cable you are using to connect the Orbi to the switch, to a laptop or PC? I'm just treying to understand better.
It is a mystery why the switch doesn't work, especially a dumb switch,. The only logical explanation for no internet is the switch or cable. There have been posts about certain green and brand switches having issues. I just read your netgear 308 is a green switch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Given the comment above about certain brands or types of switches having issues with Orbi, is there any particular model or brand that is known to be reliable?
- Mark as New
- Bookmark
- Subscribe
- Permalink
NG GS-105/108v4, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What were the issues that were reported with the green switches? Were they similar to what I am getting?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya Green Ethernet features seems to cause problems for some.
What FW version are you using on the Orbi system?
History...
Green Switch: https://community.netgear.com/t5/Orbi/switching-requirements-for-ethernet-backhaul/m-p/1653718/highl...
https://community.netgear.com/t5/Orbi/Ready-to-chuck-this-system-through-the-window/m-p/1658470/high...
https://community.netgear.com/t5/Orbi/Orbi-AC3000-with-Cisco-SG112-24-Switch/m-p/1700690/highlight/t...
https://community.netgear.com/t5/Orbi/Orbi-Netgear-GS908E-100PES-Backhaul-Connection/m-p/1784425/hig...
https://community.netgear.com/t5/Orbi-AX/RBR850-Access-Point-wired-backhaul-amp-security-issues/m-p/...
Working with Green Switch:
https://community.netgear.com/t5/Orbi/Orbi-AP-mode-and-Backhaul-connections/m-p/1966334/highlight/tr...
