Orbi WiFi 7 RBE973
Reply
Orbi stops responding overnight
Proflashrtist
Orbi with one satellite. This is pathetically slow now. Nothing in my settings changed but the speeds have basically stopped completely. What the heck is going on with this thing?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 9
Proflashrtist
Re: Orbi stops responding overnight
Bump
Message 2 of 9
Proflashrtist
Wow....what a "helpful community"...
Message 3 of 9
DarrenM
Sr. NETGEAR Moderator
Hello Proflashrist
Have you tried to adjust the wireless channels on your router? also have you enabled beamforming and MUMIMO?
DarrenM
Message 4 of 9
Proflashrtist
I can't even log into my router now I've tried with my laptop that sitting directly beside it connected to the orbi Wi-Fi and it says it's not connected to the orbi network so I can't log into anything on the orbi except for with the phone app and I can't get into those settings without a computer.
Message 5 of 9
Proflashrtist
Message 6 of 9
JoeM845
Luminary
Proflashrtist,
Have you tried an Ethernet cable between your laptop and the RBrxx? The RBRxx UI might tell you someting.
Message 7 of 9
Proflashrtist
I was hardwired when I posted this I've tried connected with ethernet I've tried connected with WiFi
Message 8 of 9
DarrenM
Are you not getting the prompt to login or is something else happening when trying to log into the router?
DarrenM
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1730 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
